1996 70hp Johnson 3 cyl
gonesailing13
At the end of the day I tilt m
At the end of the day I tilt my engine up. Recently I have noticed oil coming from the engine cover. Removing the cover I see alittle oil. Could I have a blown seal?
"not to worry....look on the b
"not to worry....look on the back,left, very bottom of the big air breather assm on front,should be a hose there,make sure it is attached,not cracked,esp where it slides on,and not pinched,it is a drain hose.also,if the breather gasket is cracked,bad,etc,u will get fuel residue out,and down,that area,...not a huge deal...more of a mess."
