[email protected]
I replaced the original heater hose to the water heater heat exchanger. I caught two gallons of coolant in a bucket when removing the old hoses and lost a couple of quarts into the bilge during the process. After replacing the hoses I refilled the cooling system through the overflow tank and started the engine.The Volvo owners manual only says "start the engine to purge the cooling system of trapped air". The engine burped and coolant starting running from the cap on the overflow tank. I turned the engine off. Next removed the larger brass plug from the thermostat housing to bleed air. When coolant came out the bleed hole I replaced the plug and added a pint to the overflow tank. I have run the for a few minutes at a time while watching the temperature gauge. The temp. gauge was up to 170 the last run. Each time the coolant everflows from the overflow tank so I remove the excess from the overflow tank, allow the engine to cool and repeat. After doing this four times the coolant is still overflowing. I assume I still have some air in the system. Any suggestion other than repeating the procedure until the coolant stops overflowing?
