Mercrazy75
I got this motor with a bad cylinder and did some machining and new pistons. I have had it running but during the lake test there is a complete lack of power. Won’t get up on plain but in neutral it will rev fine. I have cleaned the carbs and bypassed the VRO with a separate new fuel pump. When i try to set timing everything is off? The max timing is way off the scale. I pulled the plugs and checked the timing while cranking and for it to read correct on the flywheel to pointer the timer base is about 1” away from the timing stopper? How do i check the flywheel magnet to see if it has moved?
Thanks in advance!
Mercrazy75
Thanks in advance!
Mercrazy75
