1996 50fl rough idle with sterndrive up
edgar
i have a 1996 5.0fl with stern
i have a 1996 5.0fl with sterndrive up all the way crank engine rough idle the whole boat rocks cut it off crank back up idles fine could this be a u-joint problem or gimbal bearing going out also with the sterndrive down it does not do this
"If it's not a u-joint yet
"If it's not a u-joint yet, it soon will be. It is a really, really bad idea to run the engine with the drive tilted up."
the lake is real shallow at th
the lake is real shallow at the dock and i have to trim up the drive to keep it out of the mud but why would it shake real bad then i shut it off crank back up and it dont shake
"You may want to check your be
"You may want to check your bellows, there is a chance that when you trim the drive up that they well be damaged."
i plan on pulling the drive th
i plan on pulling the drive this winter to check out the drive line & bellows what gasket kit do i need to put the drive back on
