1996 225xl PLEASE HELP
F
fishinmishin
Guest
"motor runs and idles rough, I
"motor runs and idles rough, It's getting gas and has good spark. I,ve replaced the stator(1 bad bobbin), checked CDMs, crank position sensor, temp. sensor, with ohm meter. and checked throttle position sensor for voltage. Everything checked good. The tach. will not register over 1000 RPMs even at WOT. I can pull plug wire off cylinders 4 and 6 and it will smooth out and idle consideralbly better. Checked timing, it's around 2-3 deg. at idle. PLEASE TELL ME WHAT THE #$%^ IS GOING ON!!!!!!!!!"
