Remove the cable from the engine and shift the engine linkage by hand. You can do this with the engine NOT running by spinning the prop by hand to align the inner shifting parts.
Did you or someone else have the lower unit off and turn the shift rod out of adjustment?
I don't think the lower unit has ever been off. It just started not going into reverse since its been cold but I don't know if its just a coincident?
