The motor starts very easy and runs great until about 30 minutes then acts like it is firing on one cylinder or just looses power. If you wait about an hour it starts right back up and does the same thing again. It has good even compression and the ignition module was recently replaced and it didn't change anything. Does this sound like an ignition coil going bad once it warms up? There is only one ignition coil so wasn't sure if half can go bad? The fuel line is not very long and tank is vented. Any help is appreciated. Thanks.
