doug hodge
Rebuilt water pump, upon reinstalling gear box to motor, should there be a seal between water tube and water pump? I can't find any old parts that would indicate a seal. The reason I ask is upon testing via water hose, water is coming out from port/opening where shift rod goes up through housing. while running there was water pressure of 6-/+psi at idle where the never shown any pressure since buying boat 6 yrs ago. I don' have a psi tester. I don't know if this is a problem or not... Any one ??
