So from the beginning, I had a bad oil feed check valve and fixed that and rebuilt all carburetors. While running motor I was spraying combustion chamber cleaner into the carburetors and stalled the motor. I was pretty sure I flooded it but wanted to verify that all else was good so I did a spark check. I don't think I had a good ground and am pretty sure I fried something but i'm not sure what. I finally found some troubleshooting guides on the CDI website and tried to shoot the stator. I have the red stator and while shooting for resistance between green/white and white/green I was only getting about 30 ohms when it should be 500-700. I used a homemade DVA and was getting anywhere from 120 to 180 VAC when trying to turn the motor over. I started playing around with the wiring and disconnected the black/yellow wire on the switching box (saw somewhere that this might be the shut-off signal) and tried to start and the motor started. First time it's done this on at least a hundred tries. I shut it down and reconnected the black/yellow wire and it started again. I ran it for a few minutes and attempted to give it a little throttle and it died. I tried to start it again and no luck. I checked for spark with an inline spark plug tester and nothing on either cylinder. Checked the voltage out of the stator again and am only getting around 60 VAC now. Does anybody have any insight on what might be the issue? Is the black/yellow the shut-off and should it be open for the motor to start? Any help would be much appreciated.
Model #: 1-090412R
Serial #: 0G197967
Model #: 1-090412R
Serial #: 0G197967
