Hi,
After launching my boat this morning and starting it I noticed my voltage meter on dash was reading 16.5V at idol. I ran it up the bayou at 5000 RPM and it was still showing 16.5V. I put it back on the trailer and came home. I removed the cowling and started looking. I noticed the voltage regulator (top one) had a tie wrap around the wires coming from the stator to the VR and the rubber covers at the connections were fused togather. I cut them apart, put my ear muffs on motor and started it up. The volt meter on dash still read 16.6V. I checked the voltage at the battery with a volt meter and it showed 17.2V. I disconnected the top voltage regulator and the meter on dash showed 14.5V and battery was 14.2. I moved the tach wire (gray) to the bottom VR and it would not work. Left the red and yellow wires disconnected (on top VR ) and plugged the gray wire back into the top VR and the tach worked. Can I run with one voltage regulator? Can both regulators be bad? Would the stator cause the regulators to go bad? I do not have a manual on the motor SN 0G275865. Would an outboard repair shop have something to plug in to give a reading on what is wrong?
Thanks for any help.
