Group,
I'm having some intermittent overheating issues with my Johnson OceanRunner. Sometimes it runs for 3 hours and than overheats, other times I can't even idle at 1000 RPMs out of the river the boat is on before it overheats. It is the port side head and I'm hoping it is just the thermostat. Each time it does it if I remove the thermostat and clean/tap it, put it back it runs for the rest of the day without overheating, or at least the alarm doesn't go off.
Which leads me to my question. Now I don't trust it and don't want to hurt the motor. I've read stories here of guys claiming a single overheating cylinder has blown up motors, even though the alarm wasn't going off. I'm going to replace both thermostats, but I am going to bring an IR temp gun anyways just to check and make sure everything looks good.
What temperature should I get after 10 mins of 1000rpms? How about after 10 mins of 4000rpms?
If this fails to fix it, I guess impeller would be next. But I seem to have good pressure visually, and 5 to 8 pounds at 1000 to 1500 rpms, 18 to 20 pounds at 3500 to 4500. And its less than three years old. On the other hand the boat is used in shallow, muddy, bay water. So maybe the impeller is the issue.
Anyways, no matter, I'm wondering what temps I should get shooting the heads/cylinders with the IR gun.
Thanks.
Thanks.
