doug_keister
"I have a 90hp Johnson that wi
"I have a 90hp Johnson that will not plane out the boat has 15 prop tried different one. Problem is motor will not get up to WOT RPM range checked all spark good compression 120 all around while checking everything found 2 gaskets leaking gas repaired those and than found, Maybe the complete cause? Not sure until I get it all back together. (This Motor had been Rebuilt 3 years ago but never used the boat) While investigating the fuel leak I saw Smoke puff out from between the block seam. one side of this block did not have any sealer installed when rebuilt? I believe this could be the cause of the power lose under a load. Please let me know if you think it might be something else? I will post results as soon as I get this back together."
