I have a 1995 Johnson 90 cross-flow V4. It runs great... when not idling.
Sometimes it will idle fine when I first start it. Then I can run on plane all I want, but when I come back down to idle it will die. It starts right back up but i have to use my neutral rev lever to get it to start, then i have to shift into gear hard and immediately go at least half throttle.
Here's what I know so far. All of the work I have done was with OMC parts.
Compression test showed really even, 125 +/- 5 psi on each cylinder
I am thinking it's gotta be down to one of these-
I do own a leakdown tester. I have read conflicting info about what a leakdown tester can tell me. But if nothing else, I think pressurizing one cylinder with the piston at bottom dead center would allow me to follow the noise. Where is it leaking? Exhaust yeah, but where else?
Any suggestions?
Matt
- I have replaced the spark plugs several times. I am using Champion QL82C gapped at 0.030"
- My fuel is fresh ethanol-free 87 octane. I have burned like 10 tanks worth of fuel so I know it is fresh fuel.
- I have drained my water seperator.
- I have replaced all of my fuel lines going to the engine. I did not replace the fuel lines under the cowl.
- I have replaced my primer bulb.
- I have replaced my fuel water/seperator filter as well as the inline filter under the engine cowl.
- I have rebuilt my VRO fuel pump (yes, I am still using VRO).
- I have torn my carbs apart, found them completely spotless, and soaked them in a solvent tank for two days anyway. Rebuilt with OMC kit. I did take out the soft plugs, clean in there (also spotless), and replaced the soft plugs.
- I have inspected my reed valves. None of them were broken, cracked, or chipped. I was curious if they would warp under heat so I ran a heat gun over them. I could see light through three petals, but only if i blocked off all other light. From the top-down inspection, they looked just fine. I think these are probably fine, but this *may* be the issue. I have no experience evaluating reed valves. I couldn't get new ones before I needed the boat again, so I re-assembled the engine with the same reed valves and new gaskets.
- All of the gaskets from intake manifold to carbs are new.
- I took out my four recirculation check valves. They seem to be working (they only flow one way). I cleaned them in my solvent tank. A couple of my valves have a dark black in the center of the screen which i suspect is dried fuel deposits. I was unable to get these screens clean. They tested okay though, so I put them back in. I did buy four new check valves to install as my next step. I blew out the nipples on the engine heads and they flow fine.
- I have done a full link & sync every time I messed with the carbs. I have timed it using the Joe Reeves method to 24 degrees, and my spec is 28 degrees. I am confident the throttle plates are both fully closed at idle. The throttle cam contacts the cam follower at 4 degrees timing per the manual.
- I have replaced all spark plug wires. I have verified that all of my spark packs are jumping a 7/16" gap healthily.
- Reed valves
- Recirculation check valves (about to replace all of these)
- Crankshaft seals
Any suggestions?
Matt
