1995 johnson 200hp missing
oceanrunner
I have a 95 Johnson I can't get the miss out. I sprayed mixed fuel inside one carb and it raised up like gas is missing. what can that tell me?
Re: 95 johnson 200 missing
Missing is usually caused by an ignition issue. If the carb turns out to be a dead-end, try running it at night with the hood off & look for an arcing wire or cracked coil.
If not mistake, i did pull the plug on one while running and noticed the spark was arcing on the bolt that bolts the coil down. It was at night when I noticed it. Once I out the wire but on, didnt see any more arcing
