J115ELEOCThere are 2 different 115 HP models in 1995.----Rotate the flywheel??-----Shift rod MUST be set at a specific distance to avoid big $$ damage.----Model # of this motor?
When setting shift rod height the gearcase must be in neutral.When I get it adjusted to 21.25 what next? What gear will it be in? When I removed the lower it was in reverse gear.
