I bought a boat which came with a 1995 Force 40hp that had been sitting for several years. I'm going to outline everything I have done up to this point so anyone who can help will know everything I've done.
Repaired/Replaced:
spark plugs
cleaned the carburetor and replaced gaskets
discovered one of the bolt tabs on the carb adapter was broken and had no bolt present. have not repaired/replaced yet.
replaced the water pump impeller
drained/replaced lower unit oil
replaced fuel lines and cleaned the choke solenoid
After all this work I started squeezing the prime bulb and right as it started to firm up gas shot out the over flow port. I proceeded to start the motor, and to my surprise it ran but was shooting gas out the over flow. Figured out the float needle wasn't seating very well. I adjusted the tab on the float and was able to get the needle to seat better. No over flow and motor ran.
On to my problem:
I'm not sure what the ideal RPM is for idle but any RPM under 1000 is rough. The motor will continue to run but it shudders pretty hard.
I ran it for about 1 to 1.5 hours up and down the river and had no issues while running. The idle continued being rough even after the motor had warmed up and had ran for a while. I pulled the plugs and noticed the top cylinder's plug was wet compared to the lower. The lower actually had some sediment on it. I checked compression on both cylinders and both were the same. I can't recall but I want to say it was somewhere between 125 and 130 psi.
I haven't made any adjustments on the carburetor idle mix screw. I have made a couple of adjustments in the shifter linkage to help with some of the slop/tension but none of it has made any impact on the rough idle.
I have a few suspicions as to the problem but wanted to hear other's suggestions before I start part swapping.
Any suggestions?
Thanks in advance.
Repaired/Replaced:
spark plugs
On to my problem:
Any suggestions?
Thanks in advance.
