1995 evinrude 50hp cylinder head help
southla
im in the process of rebuilding the motor due to a piston having a hole in it while checking the head it has a slight low spot in the middle of the 2 cylinders my question is what is the tolerance for the head and block deck height
Just use some valve grinding compound on a piece of flat glass and refurbish / resurface the head.---------------Easy and quick to do a proffesional job of getting it flat.---------------Removes a minimum of material.-----All outboard cylinder heads warp with time, I have never taken a motor apart where the head was not warped.
