What are the compression numbers?
How does it sound when it is running?
Cleaned carbs how? Spray can, or teardown with new kits?
Was the highspeed jet that is screwed into the float bowl removed to verify it is clean ?? !
With a timing light hooked up does spark continue as motor stops / starts to die ??--------------Does it keep running if the manual fuel pump is operated ?
You should be able to squeeze the bulb a little bit!!------Try another fuel line or bulb.-------After the motor starts what happens when key is pushed in when it falters ????
Pushing the key in operates the fuel primer to richen the mixture.-------------This is used while cranking and after the motor starts you may have to push the key in momentarily untill the motor warms up.----You are advancing the " throttle only " lever to start it I hope.-------Do you have an owners manual for the motor ??
