I replaced the impeller an pum
I replaced the impeller an pump and I think the shift rod got turned in the process.When trying to put in reverse it was grinding and hard to shift.Can the rod be adjusted without taking the lower unit off again. also is there a way you can tell if its right before taking to the water. Many thanks Bighig
