I was having problems with the battery chargine and I installed a new rectifier on the engine. Once I did that the engine started right up and I was able to cruise around the lake at a variety of speeds for about 45 minutes total. This was all in hope to charge the battery.
While I was at full cruising speed the the engine RPM started to drop and then proceded to stall. After it stalled I could only get it to start with the throttle all the way forward.
I have done some testing on it and it does have spark. When rotating the flywheel with the cyl 1 (top) plug out, the TDC mark lines up with the timing mark on the engine. When using a timing light on cyl 1 the flywheel 0 deg mark shows up at about 2 O'clock on the starboard side on the engine, That leads me to believe that the timing has severly retarded itself and I am not sure how this could be.
The linkage all looks good, And I can get it started if I have the throttle lever all the way forward and then can manually advance the timing to meet the engines needs.
Make: evinrude
Model: e40TLEOD
SN: G03798924
HP: 40
Year: 1995
Make: evinrude
Model: e40TLEOD
SN: G03798924
HP: 40
Year: 1995
