"Out on the water the other da
"Out on the water the other day and although plenty of water out the telltale, got a continuous over heat horn. I put my hand under the stream and it was just barely warmer than the lake I was in. I removed the cover and had to pull both tan wires from the sensors to get the horn to stop. Both head's were too hot to touch. Replaced the water pump impeller and seals, both thermostats and the over heat problem persists with continued use over 4000 rpm's under load. It will run all day under that. I am going into the heads and replace the gaskets and water deflectors. The fishe lists a check valve but does not show where it goes or what it's function is. It is very small and looks like it plugs into the water deflector someplace. Can anyone shed some light? The book also says in one place to coat the entire gasket's with gasket sealer and in another to just apply around the water passages. Which do I do? This will be my first venture of taking the heads off and other than the obivious obstruction or bad water deflector, I don't know what to look for. I run this motor in both salt and fresh water. Model # is a e90tleor. Any input from someone who knows would be greatly appreciated. Mac"
