1995,48hp spl, removal of gear case from lower unit or foot
I have a 1995, 48hp spl that is leaking gear oil behind the prop. I have purchased the lower unit or foot seal kit, and have a puller. this gear case has 4 bolts not two, both 1/4 20 thread horizontal have 5/16 head on them two across from each other. the vertical inline two are 3/8 head with flat head screwdriver grove up and down from each other bolts, that have square with horse shoe slotted gruve keepers behind them. my question is which bolts do I remove to install my 1/4 20 allthread for my puller??? then I can extact the gear case from the lower unit or foot to remove and install new seals where leaking. please help. thank you for you time
