1995 48hp Johnson OB Prop Play.
Thanks for the reply and an oldtimer told me same thing and to in gear rotate my prop, plugs in but grounded (plug wires safely grounded to block), in FWD and REV, several times to cover all the teeth you would feel it skip.
And the Thrust bolt is from working on rack/pinion pushing the gear set together.
