I’m new to the forum and needing some info from you guys. My 48 special will dribble fuel from both carburetor throats and then make it down the inside of the cowlings and out the lower foot. I had rebuilt the carbs using aftermarket kits. Someone told me that the small round gasket that is inside the bowl for the emulsion tube is probably not right being it’s an aftermarket. I had checked the float levels and didn’t know what else to check. Advice anyone? Also the service manual calls for the air mixture screw should be adjusted at 3turns out. Mine will only run 1 1/2 turns out. Does this relate to the fuel issue?
