ok so heres what I have done so far Ive taken the carbs off cleaned, then replaced the inline filter, installed new primer ball.taken apart the fuel pump and checked the dioframs (good) and still not getting fuel to the cylinders. if i spray mixed fuel down the carbs it will run till that fuel is gone and then shut down. when I pump the ball it will build pressuer but when i stop the fuel thats in the filter drains back into the tank. is that right ? and if not what would cause this. any help would be good I would like to get it on the water this weekend thanks.
