G
Greg Reid
Guest
" After running about 20 min a
" After running about 20 min at close to full power i cut the moter for about 3 min. When i restarted it would crank and idle, even rev up in neutral, but when i put it in gear it would die. This went on for about 15 min. Finally i took the cover off cranked it up, put in gear and it ran fine. What could have caused this? Could it have been too hot. Should i replace the impellar?
It also runs a little rough at an idle.
The boat is new to me and this was the longest continuous run I had made with it. "
