C
coolcatcj1
Guest
"Can anyone please help me?
My 1995 25 hp johnson outboard starts and runs great at idle and partially revved the problem is when revved past 1/4 thottle but not always, sometimes it will take off just fine and then seconds or minutes (depends on the day) later it cuts out violently but doesnt die, if you let off throttle it returns to running fine but this makes for a slow (5 mph) ride to next fishing spot.
I have taken off and cleaned carb, I have tried a new coil on both cylinders thinking a coil was cutting out. It does seem to be less troublesome when cold and it seemed to be better after i messed with the electronic advance but now is back to same.
ecm maybe?
Any help would be GREATLY APPRECIATED.
Thank you in advance"
ecm maybe?
