Troubleshooting, no spark either cyl. Disconnected the blk/yel kill wire from switch box, no spark. Suspect either the ignition stator coil (resistance readings between red & blk wires 128 ohms, no continuity between blue & blk or red & blue, or any of the wires to ground) or switch box. Trigger coil resistance OK? ( 690 ohms between brn/yel & brn/wht wires) Ignition secondary coils seem fine. Any troubleshooting tips to narrow problem to either ignition stator or switch box. With a convention multimeter can voltage be checked at ignition coil primary wires (grn/wht & grn/yel)? Thanks for any suggestions.
