1995 225hp Johnson Ocean Pro
sam_h
"Initial start-up is very diff
"Initial start-up is very difficult if my engine starts at all.Once started and shut down, engine will fire up over and over all day.I rebuilt all carbs and replaced electic choke but still the same.I think I have a flooding problem since after tilting motor back and forth I got it started. Ineed help. Thank You"
do you have any other problems
do you have any other problems at any other times? sounds like maybe you might still have some crud in the carbs or worse water contamination. are you runnin a water/fuel separator?
