Unfiltered
Good evening. I have twin 200hp Johnson Ocean Pros on my 1995 Grady White 272. In the beginning of the season I noticed low voltage from my house battery (electronics) with the engines off. When running my GPS would should about 12.5v - 13v. Even after being on the charger at the dock there was no change in the problem. I replaced the house battery with a marine deep cycle/starting battery that I had bought for my camper but, was not using. Since adding it I now notice that the entire system is overcharging. I am showing 15v - 16v on both engine battery voltmeters and roughly the same on the reading from my GPS (house battery). I have also been blowing the fuse for my spreader lights (unknown if related). At idle voltage on the GPS seems to be around 13. I did not notice what it was on the engine voltmeters at idle. Without the motors running voltage to the GPS shows as about 11v. Again, the house battery is new.
Any help on trying to troubleshoot this problem would be appreciated.
Thanks!
Thanks!
