"Got a 1994 Four Winns 19ft wi
"Got a 1994 Four Winns 19ft with a 5.0 Volvo gas engine, serial # T01273537, Model # 502ACPMDA. The boat operates in fresh water and at the last outing it immediately heated up to over 240. The raw water impellor was slipping on the shaft, replaced it and the thermostat. I lubed the new impellor good with glycerin to aid in dry startup. With the boat sitting in the water, it immediately heated up to 240 again, and I couldn't detect water in the exhaust at the prop. (Probably melted the new impellor!)Where did I miss it? Is there a way to prime the pump before starting the engine? The inlet ports on the lower foot look perfectly clean, however this boat by necessity runs in some rather shallow water to get to the boat lift where it stays. How do I check water flow to the pump, and where can I down-load a diagram of the cooling system for this engine? Thanks in advance."
