A
AdamL
Guest
"I have a 1994 PCM 5.8L motor
"I have a 1994 PCM 5.8L motor with the Pro Tec electronic ignition and carb. The motor has always run great, but I didn't use the boat this season and now it won't start. It cranks fine, but I'm only getting spark at 2 cylinders. Checked the wires, all visible connections, and battery condition. All seem fine. The coil modules look fine as well (no rust or cracks anywhere) Dose anyone know more about this ignition system or have experienced similar symptoms. I found a kit that replaces the Pro Tec with a normal distributor setup, but I'd rather not spend the money if this is just a bad connection some where. Any and all help is much appreciated. Adam"
