I did a rebuild on a 90 Force a couple years back. The block actually has quite a bit of "meat" to it. The machine shop bored all three cylinders to 30 over and said there was still lot's left (you can get 45 over pistons/rings for this model).
Force takes alot of crap (some deserved), but the block itself is actually fairly well built - it's the crappy carbs (old Merc Tillotson's that Merc stopped using in the mid 70's) and that cluster $%&# ignition, aka, Prestolite.
My advice to you is get the machine shop to source your parts, forget about using a Merc dealer. Wiseco makes pistons/rings and most shops can get Torrington bearings (or even Timkins), which is all you will get from Merc (paying double the price for the Quicksilver logo).
And yes, the above comment is correct. Simply unbolt the powerhead and pry then lift it off.
Don't forget to correct the likely source of the failure in the first place - the piston or cylinder is the result - the culprit is likely the carb(s). Rebuild them just on general principle.
The total (restore) cost for the one I did was just under a grand. That included, 3 new holes bored (that was $150 at the shop plus 25 bucks to put a helicoil in the number 2 sparkplug hole - when the pison went and the rod broke (or vice versa) it really launched and drove the plug right out of the hole - kinda cool
) , 3 new pistons, rings and connecting rods. New bearings - crank - upper lower and main, and rod bearings both ends, powerhead gasket kit (for that you should use OEM), 3 carb kits (again OEM on these - Tillotson parts are getting scarce - the kits are close to the only source now), new trigger (coincidental? - but appears to have died the same time as the number two piston ate it's rings, broke the rod and toasted the cylinder) and waterpump kit.
Like I said, the machine shop sourced all the "guts" (pistons, rings, bearings, rods) - got all 3 for what Merc wanted for a single piston/rod. Carb kits/powerhead gaskets from Merc. Waterpump kit from Sierra (Merc stopped making impellers for these - grab a couple extra's in the aftermarket now or you will be out of luck when the last of the stock runs out).
