artie in miami
I noticed that my port engine of my twin 175HP mercs runs about 20 degrees hotter than the starboard engine. I changed the impeller and water pump housing and it is still hot...the water coming out of the peehole is so hot at idle (with the earmuffs on) that it would scald your hand if you held it in the stream for any more than a second. At high RPM (around 3000), the temp drops down to about 140-150 degrees...at low RPM, it is right around 180-200 degrees. Has anyone else ever seen this situation ? The other engine runs about thirty degrees cooler when both are at low rpm.
I had the boat stored for about two years...before I stored it, I did not have this problem...it suddenly appeared when I started to use the boat again.
artie in miami
artie in miami
