1994 mariner30 hp
mariner30
"My motor is very sluggish and
"My motor is very sluggish and stalls out when put in gear, motor automatically mixes oil and gas but resivor is still full of oil, does my fuel pump mix this together and do you think it might need fixed. I pre-mixed for now 6gal. gas 16oz. oil have to go very slow or it stalls out."
"Kirk, just want to make sure
"Kirk, just want to make sure we have the right motor here. You state it's a 94 Mariner, 30 horse.
That would make it a Yamaha built motor (serial starting 6E9-5xxxxx).
If so it will have an autoblend system (tank etc that you plug the gas line from the tank into then another line goes up to the motor).
If not you need to post your serial so we can tell for sure just what you have there.
Aside from whatever your oil system is, from what you describe it sounds like you have a clogged up carb. However, before we even go there, post your serial.
If you have an "auto-blend gone bad" motor it's possible that some severe damage has resulted from lack of oil...."
