I believe my sender is bad. I bought this used boat and like 1 gauge of the 6 worked so I replaced them all. After replacing, the trim gauge doesnt read right (and yes I got the johnson evinrude gauge). The gauge has a good ground and good 12v power. Now when I test resistance on the sending unit wire...as the lever is moved, it only gives back a reading in a very small portion of the movement of the arm. When the motor is trimmed all the way down or I manually depress the lever, there is a small range of motion where it sends back about 59-62 ohms of resistance. When its all the way up, it shows nothing...and nothing when depressing most of the range...when I get to one point, it will register a little and it makes the needle move on the gauge.
My question is, from the sender, where does that sleeve of two wires go? I can see it going up into the motor casing, but cannot find it inside anywhere at all. Ive read it goes to the relay control trim box, but I dont see it on there. I can go back and look harder, but I do believe the wires that come from the sender have a plug on end, by looking at schematics.
Basically, I want to buy and install a new sender, but want to know how to install the wires...where do they go from the sender?
thanks!
thanks!
