1994 Johnson Fast Strike question
tommyboy
Hey guys...I'm mounting this motor early next week. My question is that I need to mount the engine at work. I have access to a fork lift there. The motor is trimmed all the way down. I need to trim the motor up so I can drive it home. Is there some kind of manual release I can trigger so I can tilt the motor up? It has power trim, will not be connected before I go home.
The easiest way to do this, is to connect a battery to your battery leads temporarily then use your tray mounted trim switch,
If you dont have the battery leads on the engine, just use jump cables.... That V6 can be heavy to lift on the manual release...
