dimitrimfogal
hey guys , this engine had a shifting problem and was stuck in forward gear , from this site i was told that my drive balls had sheared so i began to tear it down to replace them..at this point i have the lower case removed , prop , forward gear , but i cant get the prop shaft out past the gear that is pressed into the case (#17 ?) how do i get the prop shaft and reverse gear out to replace the drive balls? thanx in advance...dimitri
