1994 Johnson 70 Outboard
larry1
"I recently bought a boat with
"I recently bought a boat with a 94 Johnson outboard. Ihave not had it out in the water yet, but decided to test the motor first in a barrel.The motor starts alright but idles fairly rough and I notice a lot of smoke when I rev it up. There is also an oil film around the bottom end of the motor. I phoned every service place I could in my area but they are all booked until late August. Does anyone have any ideas which could help me out. Thanks."
"dont be overly concerned..
i
if this eng has set awhile--
do the carbs
water imp
tune up
if it has not set up,say a yr w/out use...take it to lake and see how it does."
Thanks for your input. The boa
Thanks for your input. The boat has sat for over a year without use. I put fresh fuel in and will do the carbs/tune up. Do you think I have to do the Impeller if there is lots of water coming from the pee hole?
