1994 Johnson 48 spl low end chatter
cosmict
I have a 94 48 spl model # J4
I have a 94 48 spl model # J48esler That I just recently put on a 15 ft Riviara. I rebuilt the carbs and seems to idle low But my question is when I shift into gear I hear a little chatter then feel a a few bumps but when throttled up it seems to be ok. I have never had a johnson so i dont know if this is normal. Also Spitting good water at low speed but when cranked up it looks like mist. I plan on changing Impeller should I change pump as well? comp. is 125psi on both cylinders.
"i think,u need to adj your sh
"i think,u need to adj your shift cable,to have more travel in forward.the impeller,is,..the pump."
"1992 Johnson 48hp
How do I r
"1992 Johnson 48hp
How do I remove lower end to replace water pump,
I believe I put shifter forward, do I need to disconnect
the shifter rod? and if so, were can it be found?"
"Bigking, best to start a new
"Bigking, best to start a new thread as it will likely get more views.
The shifter rod disconnects up under the carbs, its a tight squeeze to see it.
Don't forget the hidden bolts under the trim-tab on the bottom end.
A manual will save you from making expensive mistakes :)"
