1994 Johnson 200 tach problems
subwayjo
"Hi, I have two engines and th
"Hi, I have two engines and this problem is intermitten on both engines. when I turn the ignition key to the on position, the tach goes to 3000 rpm, sometimes it will last all day. today I had the problem on the starboard engine when I first started it, by the time it warmed up it was down to normal."
Is this a problem that just st
Is this a problem that just started or you have always had it? Sounds like you have 1 switchable tach?
"its poss,.....but w both doin
"its poss,.....but w both doing it,...ck and clean/tighten all conn's inder dash.....it sounds l;ike a bad ground conn since both are acting up..."
