fastdaddy55
Got a 90 hp that has a miss in it at WOT. You can run it all day at 3/4 throttle & it won't miss a lick. When you go full throttle it will run about 100 yards then start missing & won't stop even if you go back to 3/4. It will miss until it almost stops. It acts like it is only running on about 1 to 2 cylinders then will eventually clear up & run fine unless you go back to WOT. It is always hard to start after it sets while you are beached for a few hours. Most all the electronics have been replaced with CDI stuff. Any Ideas? Thanks, Scotty
