I went to pump the bulb and it took quite some time to get firm. Usually it’s a couple pumps but now it takes a lot until it gets somewhat firm. I can hear fuel going somewhere. It starts every time but it starts up very slowly (low rpms the finally gets up) after sitting idle for a couple minutes it’ll slowly sputter and die. This has been an issue for years now but every time my neighbor just turns the idle up saying that it should fix the problem which is does temporarily. Now I can’t get it to stay running unless I put it in gear but even I’m gear if the rpms aren’t up enough it’ll slowly sputter and die. Could the fuel pump be weak/failing? Or could it be something else. I find it odd that it runs fine then does after a couple of minutes. Also whenever I try to go full throttle it seems as though the engine revs and the prop does not turn. If anyone could just point us in the right direction that would be awesome.
