well to start just brought boat this spring, had it out on local lake . first two time no probleams. third time out while on water not very fast, so brother tried to turn adjustment screw on throttle cable. thats when motor started running real ruff and over heat alarm sounded. don't know if adjusting throttle cable had anything to do with it or not. note when boat was first purchased i replaced the overheat alarm due to it being fried. then took advice and pulled the t-stat which was gutted and only top remained. then pulled exhust side cover and found an home made gasket which had three out of four water ports completely covered.allowing no water to flow around the head at all.the only port open was the one that let water flow out of nipple on exhaust cover and out water tube. well replaced all ehaust gaskets with factory new. note forgot to mention also replaced head gasket. well put every thing back togeather , have excellant water flow from all areas ,water tube, exaust area and prop area. new probleam can not keep engine running at idle or any other steady speed, have to keep moving throttle back and forth to keep running . keeps stalling and have to choke each time to get started,oh yea have to keep pumping bulb on fuel line too. well thats the complete history .sorry it took so long to get back but was waiting on back order og gaskets.any help will be greatly recieved.
