1994 evinrude 150 hp E150WTLERV Temperature Switch, Port
bobbydigital18
The Temperature swtich that comes out of the port block has two wires a tan and a white i beleive the tan goes to the alarm but where does the white go and how can i get a temperature gauge to work with this?
The white wire cancels "Fast Start" when a specific temperature is reached.
If you see a threaded hole on the cylinder head, that would be where a temperature sensor would be installed. There is also a kit that contains a "L" shaped bracket whereas that bracket would be attached to a head bolt to hold a heat sensor.
