davesmith02
What is the initial carburetor adjustment?
Yep, that's about right.I'm sure someone smarter will give you the exact answer, but I've been told to screw it in completely, then open it one full round and a half. Then adjust it as needed.
That is way more opening than needed. It sounds like this carb has a restriction and needs a full cleaning and rebuild kit.I wound up turning idle adjust screw in. It runs fine at 4-3/4 turns out. Goes into gear without stalling (on muffs not in water). I'll see if it works it's way out by itself after a few times out. At 7 turns out it's just losing its spring tension. Don't know how it can move by itself at 4-3/4 but I'll find out.
