jcardinale
"I have a 1994 suzuki DT40. Mo
"I have a 1994 suzuki DT40. Motor sat for a long time, so I rebuilt the carb and fuel pump. New fuel lines and filer. Engine is difficult to get started. Once it starts, it will run ok for a few minutes, then bogs down and sputters, then stalls. Then it will not start, but if you wait a little bit and crank again, it will fire back up and repeat the same process. Was able to keep it running for about 10 minutes at higher rpm, but when you try to let it idle it will just sputter and die again. Also sounds like it is miss firing. Any suggestions?? Do not want to pump money into this thing if it is a serious problem"
