"I have been trying to get the
"I have been trying to get the motor to lower with the trim switch but the pistons on the trim were all stuck. I removed the cap like I saw on another thread and let it sit for awhile. I came back and tried it again. The trim motor worked in both directions and I let it down a bit, came up a little to see that it worked in both directions and it did. I went and let the motor down till it sat on the lower pistons and tried to move the motor back up to make sure it worked in different degrees but absolutely no electrical power was being sent to make it go back up a little. It would continue to lower with the switch but wouldnt work in the upper. can you give me a hand with this. Also, I have been looking for what type of oil to use for this early 1990's model 90hp Evinrude. E115TLERC"
