I purchased a fuel pump to rep
I purchased a fuel pump to replace the injector pump and plugged off the Intake manifold hose that used to be connected to the oil injector pump. The new fuel pump has to ports to connect one from gas line source and the other to Carbs. I cannot find the peep hole to connect or mount the fuel pump to the engine so that it will have the pressure required to pump gas. Where is the mounting location for this pump. Johnson makes a 3 port pump do you know if the third port would take the place of the need for a peep hole on the engine. Should this peep hole be on the intake manifold in case?
