Craig Knable
I have a 1994 70 HP Evinrude VRO Deleted, 50:1 Mix engine that is new to me. The engine has 120 PSI on all 3 cylinders. I rebuilt the carbs when I got it cause it had been sitting for a few years and also did lower unit maintenance. It ran rough. so. After rebuilding carbs it made it run better. But, would only do top speed if i primed the bulb while ALSO holding the choke (little red lever) in the right position it would seam to run a bit better, but only for a short time. I have rebuilt the choke (top side gaskets and lever) twice. It squirts gas out all over the place. I took it to my only 2 stroke guy in town and he said it was a bad power pack and one bad coil. I got it back and onto the water today and its like nothing was done. Can i just literally remove the auto choke ( lines and all from Fuel pump) as i do not think it is needed and it is causing me a sever headache. Fuel is POURING from this location. Here is my line of thought. Fuel needs to get to carbs but is routed through solenoid. Solenoid leaks like a sieve and doesn't allow fuel to bowls. Delete choke and fuel goes where it is needed. I paid a guy 800 dollars to repair my motor and im still in the same situation. Thanks for any help. Have been reading my brains out trying to find out if deleting a choke is allowable.
Edit My mechanic linked and sinc'd the controls and timing as well. He has done good work for me in the past.
